RT-AC86U WAN Port intermittenly goes down
Youst
Hello,
I am having a AC86U and the WAN Port is keep bouncing few times a day and only few seconds each time.
Apr 28 03:32:08 kernel: eth0 (Int switch port: 3) (Logical Port: 3) Link DOWN.
Apr 28 03:32:11 kernel: eth0 (Int switch port: 3) (Logical Port: 3) Link UP 1000 mbps full duplex
The cable has been replaced few times and also I called my ISP replaced modem 2x but issue remained, if I connect my old linksys router, it never drop, it seems this AC86U keep taking down the WAN port, so wondering what could be the reason?
Thanks.
To isolate WAN port issue setup temporary Dual WAN with LAN port as main WAN. Use the router this way for a while. Check if disconnects happen again. I had one RT-AC86U replaced with failing WAN port.
