RT-AC86U Watchdog & mtd9 scan
CaptnDanLKW
I noticed this in my logs yesterday. Never seen it before. RT-AC86U with 384.18_beta1
It seems that something went wrong and the watchdog daemon caught it, but I'm bewildered by the actions taken. Perhaps a listing of the function <> partition mapping can shed some light?
Is mtd9 really the nvram partition, that was seemingly mounted as a file system, checked, and then dismounted and released back to the OS?
Hardware fluke, software bug? Thoughts?
Jun 27 16:51:23 RTAC86U check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Jun 27 16:51:23 RTAC86U rc_service: check_watchdog 1312:notify_rc restart_watchdog
Jun 27 16:51:23 RTAC86U custom_script: Running /jffs/scripts/service-event (args: restart watchdog)
Jun 27 16:51:24 RTAC86U kernel: ubi1: attaching mtd9
Jun 27 16:51:24 RTAC86U kernel: ubi1: scanning is finished
Jun 27 16:51:24 RTAC86U kernel: ubi1: attached mtd9 (name "misc1", size 8 MiB)
Jun 27 16:51:24 RTAC86U kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Jun 27 16:51:24 RTAC86U kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Jun 27 16:51:24 RTAC86U kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
Jun 27 16:51:24 RTAC86U kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Jun 27 16:51:24 RTAC86U kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Jun 27 16:51:24 RTAC86U kernel: ubi1: max/mean erase counter: 9/5, WL threshold: 4096, image sequence number: 113886647
Jun 27 16:51:24 RTAC86U kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Jun 27 16:51:24 RTAC86U kernel: ubi1: background thread "ubi_bgt1d" started, PID 10686
Jun 27 16:51:25 RTAC86U kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram", R/O mode
Jun 27 16:51:25 RTAC86U kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jun 27 16:51:25 RTAC86U kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
Jun 27 16:51:25 RTAC86U kernel: UBIFS (ubi1:0): reserved for root: 275879 bytes (269 KiB)
Jun 27 16:51:25 RTAC86U kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID DA02FFC9-330C-43B0-884B-CD262F788227, small LPT model
Jun 27 16:51:25 RTAC86U kernel: UBIFS (ubi1:0): un-mount UBI device 1
Jun 27 16:51:25 RTAC86U kernel: ubi1: detaching mtd9
Jun 27 16:51:25 RTAC86U kernel: ubi1: mtd9 is detached​
Searching the forum those UBI messages appear to be pretty normal. So unless you're seeing a lot of them I'd ignore it.
