RT-AC86U weird issues
timofeid
Hello everyone,
Recently I've upgraded my trustworthy RT-N18U to RT-AC86U in order to achieve greater VPN speeds and 5 GHz. I've immediately flashed stable Merlin firmware 384.12, reset it to factory and configured the thing.
Wi-Fi is 2.4/5GHz SmartConnect (default settings), ISP is simple DHCP. No QoS, IPv6 etc.
Life was great… for a couple of weeks.
Today all of a sudden my wireless devices started to randomly lose Wi-Fi connection for long periods of time while the wired ones are working fine.
Router's web interface became extremely laggy, sometimes pages are simply stuck loading, Wi-Fi on the top icon is often half-green and a pop-up says 2.4 GHz is using channel 0. CPU load is below 5%, no overheating, RAM usage is about 50%, device itself is far from hot to touch.
After some googling I've tried 2.4/5 GHz SSID separation, N and legacy modes, 20 MHz bandwidth and manual control channels but to no avail, as well as factory reset — after quick initial setup is slows down to a crawl almost immediately.
How can I diagnose this issues? SSH access is working fine.
Thanks in advance.
Hello everyone,
Thanks in advance.
Try testing with a tool like wifi analyser to see if you are using a channel that is getting interference
Also how are LAN clients fairing in preformace.
Users of the AC86U in South East Asia have posted a lot of complaints about 2.4GHz wireless failures on units bought from China. It could easily be a hardware fault. But one software thing you might want to try is turning off WPS in the advanced wireless settings.
Thanks, I've checked it — no more than 3 networks per channel and there are always a couple or more of "free" channels available with weak <-80 dBms networks.
Thanks, I always keep WPS off.
I'm not in South East Asia region but the label says H/W Rev. 1.5, Made in China, 2018.
Similar issue here. Upgraded from 87U to 86U a few weeks ago, and the fun started... I experience WiFi disconnections for short periods of 10-60 seconds once or twice a day. When it happens, all clients show they are connected to WiFi, but I can't even ping router. Minute later, everything starts working again. Router has a sticker that says it was manufactured on 2019 in China, so I guess it should have all the hardware bugs (if any) resolved.
In my situation, the issue is not related to crowded channels because I only have one neighbor, so there's no interference. And this issue randomly happens not depending on number of connected clients (very often my PC is the only connected client).
P.S> As per suggestion at https://www.snbforums.com/threads/major-issues-w-rt-ac86u.56342/page-5#post-504892 I just disabled airtime fairness to see if that helps.
