RT-AC86U with 384.17 shutting down completely
ObeliskAG
Not sure how to best report this issue.
My RT-AC86U was upgraded from 384.15 to 384.17 on May 15th. Since then the device has "gone dead" twice. The symptoms are no connectivity from LAN or Wi-Fi, no LEDs on the front panel - it appears the unit has been switched off - but it has not. Turning the power switch off, pausing, then turning back on, restores the device to full functionality.
There are no entries in the System Log regarding an error.
I am considering reverting to 384.15 but I am wondering what other peoples experience has been.
Search this forum for this model and you'll find plenty of posts about it.
It's common with your router model when it restarts.
I did search the forum and nothing lept out at me about the AC86U hanging up. The issue isn't when the model restarts, it is many days later when it crashes.
As my search didn't turn up the right results, could you post a link to a relevant thread please?
  • Like
Reactions: a5m
Those are the exact symptoms with that router model for a restart that never fully ran.
The syslog would not show any helpful info as at that stage it cannot write to the syslog.
https://www.snbforums.com/threads/ac86u-sometimes-powers-completely-off-during-reboot.48296/
https://www.snbforums.com/threads/rt-ac86u-hangs-on-reboot.55748/
https://www.snbforums.com/threads/384-15-soft-reboot-did-not-complete-86u.62486/#post-557513
https://www.shaolintiger.com/2014/03/17/asus-rt-ac68u-keeps-rebooting-restarting/
Hi thelonelycoder,
Thanks for the links. I had not considered the scheduled restarts could be involved.
Unfortunately, as the router is scheduled to restart on Fridays, this would not explain the outage at the beginning of the week, but might explain today's issue. I will disable automatic restarting and see what happens over the next week.
Regards,
ObeliskAG
Did you do a full reset/initialize of the router after the firmware upgrade or did you just install the firmware and that's it, aka a dirty upgrade.
My unit is fine.
The only thing I've modded is by adding a 120MM fan on the back, temps are a constant 43 degrees.
Hi, just as a FYI, I own a new AC86U (3 months) and just recently I will get up in the morning and look at my AC86U and lo & behold, no LEDS are on. It's like I had turned it off. I'll then turn off the power, turn it back on and it's running fine. I wll test for this but I never considered that it was on and still working but not showing the LEDS? In my setup I'm using the 86U as an AiMesh node with a wireless backhaul to my RT-AC5300. Both units are running the current Merlin firmware in a fairly vanilla setup.
Sent from my SM-T830 using Tapatalk
There's a button at the back to turn LEDs off and on, and a setting in Administration / System. Also, amtm has an LED scheduler function. Make sure none of them are pressed or activated.
Yes, thanks, I'm aware of those. When I said "get up in the morning" it was implicate that the router was on, OK when I went to bed so the LED's turning off happened during the night, on it's own…
