I know these builds are alphas, but I didn't know where to post this, so I'll post in here for you merlin.
Last week I was having problems flashing my router after installing alpha 1. I could flash via the Asus utility and the flash would work fine. but the router would always fail flashing via network.
With the router running on a firmware build from the 13th of this month - when trying to update the firmware with a build from today - the router goes through the flashing sequence, says it's successfull, but still has the old files on from the 13th.
It flashes successfully via the Asus utility though.
I have only started having these flashing problems in the last few alpha builds - I just thought the Merlin should know, there's a possible fault in the firmware (BTW I used a clean build of Ubuntu 14 and a fresh download from the git hub to build the latest alpha 2).
I'm on build version - 378.53 alpha 2 (d6a4781).
Here's hoping the next build will flash properly over the network rather than using the Asus utility.
