RT-AX58U- 386.5_2 - Random disconnects both ethernet and wifi
bojji
Hello guys!
I've recently purchased an RT-AX58U and installed merlin on it and I'm having weird connection drops ever since. (Both ethernet and Wifi affected)
Everytime that this happens the logs are registering this: (No other recent activity besides that messages)
Apr 22 18:45:30 kernel: httpd (1489): drop_caches: 1
Logs for the same timestamp as the message:
Apr 22 18:01:14 hostapd: eth5: STA WPA: group key handshake completed (RSN)
Apr 22 18:01:14 hostapd: eth6: STA  group key handshake completed (RSN)
Apr 22 18:01:15 hostapd: eth6: STA  WPA: group key handshake completed (RSN)
Apr 22 18:20:01 acsd: eth5: selected channel spec: 0x100a (10)
Apr 22 18:20:01 acsd: eth5: Adjusted channel spec: 0x100a (10)
Apr 22 18:39:06 acsd: eth5: selected channel spec: 0x1009 (9)
Apr 22 18:39:06 acsd: eth5: Adjusted channel spec: 0x1009 (9)
Apr 22 18:54:23 dnsmasq-dhcp[14819]: DHCPDISCOVER(br0)
Apr 22 18:54:23 dnsmasq-dhcp[14819]: DHCPOFFER(br0)
Apr 22 18:54:23 dnsmasq-dhcp[14819]: DHCPREQUEST(br0)
Apr 22 18:54:23 dnsmasq-dhcp[14819]: DHCPACK(br0)
The router sits almost all the time around 0% CPU utilization and has 250MB RAM Allocated
And I cannot find information about that message.
Any ideas?
Use the Better Search function at the top of the page.
All those messages are normal. The drop_caches message is generated when you log into the router's GUI.
At 18:39:06 your 2.4GHz WiFi changed from channel 10 to channel 9 because it had less interference. That may be the cause of your problem. Change the 2.4GHz Control Channel from Auto to 11. Change the 2.4GHz Channel bandwidth to 20MHz.
Hi @ColinTaylor,
Thanks for answering and for clarifying that!
That would impact ethernet connectivity? because the problem that i'm having is both affecting Wifi and ethernet.
I logged in immediately to the router when I noticed that behavior, that's why I thought it was an error message.
I'm also using an AX58U on 386.5_2 and am having similar occasional drop out issues both on wireless and ethernet. I haven't figured out what's causing it yet.
Hi @Riley600!
Have you seen any error message on your sys logs? have you experienced the same behavior using the official firmware?
Edit: I've switched to OFW 3.0.0.4.386.48631, I will report back if the problem persists or if it gets solved
Hi @Riley600!
I haven't noticed anything in my system logs but will check a little more diligently next time it happens. I haven't used the official firmware for a while, so I can't comment on that (although it looks like you switched and still have the issue).
I don't really remember this issue before 386.5, so maybe there's an Asus firmware bug? I did do a factory reset, however, the problem still persists albeit maybe it occurs a bit less often.
Hi @Riley600,
I followed @crkpot suggestion and performed a hard factory reset and the problem seems to be solved.
I will update the post in a few days to let you know if the problem reappears.
Hi @Riley600,
Hi @bojji
Is your router still problem free? The issue is getting worse for me...I did a factory reset already but am contemplating doing a hard reset as mentioned above with hopes that it'll fix the issue.
