Solved RT-AX68U_386.5_2: LED lights up automatically after power up
king5201
I turned the LED off on the router app.
Sometimes I turn the router power off during the day.
When the router powered on, the LED lights up again (the same result after trying many times )
I need to open the router app to toggle the LED setting from off to on then turn off again
Is this a bug?
Or is there any setting that can be adjusted?
When the router powered on, the LED lights up again (the same result after trying main times )
Is this a bug?
sounds like maybe the router is toggling the light before it determines the correct time of day maybe? (this is just a conjecture comment). I would recommend looking into AMTM's router light control.
Thanks for your tips
After checking the AMTM, no light control script is enabled.
Then I disable the led via console
nvram set led_disable=0
nvram commit
Now the issue is solved
I think it might be a bug of the router app
I've had a similar problem when using the amtm LED script. In my case, what sometimes happens is the LEDs fail to go off at the designated time. I've unistalled the script for now, but when I have more time, I may try it again and see what happens. Would there be any clues in the system log to look out for in order to find out what was causing the problem?
I don't found any enter on the log with the world LED. Maybe it's other world for this functionality ? When i set On/off , i don't see any log activity...
I don't use AMTM.
