RT-AX82U - Using with Sky Fibre
loading5
Hi, I am from the UK and use Sky Fibre as my provider. I am aware of the DHCP 61/MER method Sky use as a means of connection. I want to swap the modem for a Vigor 130 and then use the AX82U.
I have made a mistake it seems in purchasing the RT-AX82U to go with a Vigor 130. The RT-AX82U does not currently support Merlin (will it ever?) and the option to configure using DHCP 61 is unavailable.
Is there an alternate method to enable this functionality, or am I totally reliant on a future Merlin release? Also, why isn't this an option by default with Asus? They have many ISPs to choose from in the setup, but not Sky.
Thanks in advance.
i would also love an up date on this as well are we going to be seeing a future Merlin release for the RT-AX82U or can we use another models up date?
A while ago I was able to make my RT-AC66U_B1 working with stock firmware by changing some NVRAM settings:
nvram set wan_clientid_type="0"
nvram set wan0_clientid_type="0"
nvram set wan_clientid="001122334455@skydsl|abcd1234"
nvram set wan0_clientid="001122334455@skydsl|abcd1234"
nvram commit
reboot
BUT, I was not using generic values as I was able to extract user/password from my Sky router.
Hope it helps.
nvram commit
reboot
Hope it helps.
Wait how do you do this
@thewizard1241 Did you manage to get this working? Just got an RT-AX82U and was looking to do the same thing to replace the Hub for my Sky Superfast fibre, but just waiting to get the Vigor 130.
