stevenhurwitt
I have my RT AX86U set up at my girlfriend's apartment and in the past have set it up to port forward ssh on my raspberry pi.
I've been trying to debug this for awhile and have a DDNS set up so I can do `ssh [email protected] -p 12345`, but if I'm off network I get a connection timeout.
The weird thing is I know the port forward works, when I'm on network I can only connect through the ddns if the port forward is set on the router. However when I tried a scan from a website it said the port was closed.
I would like to connect off network so I can ssh into my pi from the place where I live. I saw a similar post where someone had the same problem, the only port I can access off network is the router settings page at https://thisismyddns.asuscomm.com:8443.
Has anyone successfully solved this problem? I'm not sure if it's something at the ISP level but it worked before we moved apartments...
Thanks,
Steven
Thanks,
Steven
