RT-AX88U has a serious bug with firmware 3.0.0.4.384.9566 (random reboots)
Spartan
So I recently got an RT-AX88U which runs great other than the random reboots. I saw some posts about it here and did all the suggested resets and whatnot to no avail. I also tried the latest Merlin Firmware but it was a no go for me because the VPN that I setup in the client VPN (L2TP) gets deleted after a reboot. This is on both 384.19 and 384.18 causing me lots of problems as I use an IP phone for work which needs to the VPN so having to recreate it every time a big hassle.
So today I tried downgrading to the previous official firmware from ASUS v 3.0.0.4.384.9559 and now all is fine.
I can confirm the same issue. We use 2x RT-AX88U AX6000 in our workplace and both have intermittent / random reboots (1-3/day). The outages last around 1-2 minutes as the ASUS seemingly reboots.
The first couple of log entries after the router recovers (to help with people searching for log entries in the future):
Oct 9 14:08:28 rc_service: ntp 2214:notify_rc restart_diskmon
Oct 9 14:08:28 disk_monitor: Finish
Oct 9 14:08:28 disk monitor: be idle
At first, we thought it was a DNS issue, with the WAN failing on the ASUS RT-AX88U, and the broadband/DSL working fine on the modem. After changing DNS servers and setting up various monitoring tools, we soon discovered that the ASUS Router was not responding to ping requests during a network failure (though other devices connected via Layer 2 switches were working fine between each other).
3.0.0.4.384.9566 isn't stable, 3.0.0.4.384.9559 has been rock solid.
We use most features of the RT-AX88U (DHCP, QOS, AiProtection, AiMesh, 2.4+5Ghz WiFi, Guest WiFi, static routes, port forwarding, etc) and I am unsure which of them are the source of the issue.
Thanks for confirming this. I am using 0 extra features other than a VPN Client in the router. Nothing else has been touched, no AiProtection, no QoS, nothing! It's just one buggy firmware and ASUS hasn't updated it in 2 months!
So glad I sold my AX88u and got AX86U
RT-AX88U and RT-AX86U share the same CPU and same 5 GHz wifi chip. Only the network switch and the 2.4 GHz SoC are different.
Got to chip in here. Latest fw on the XT8's also has the same problem. I then disabled AiProtection, and no more reboots.
Hate disabling AiProtection, but at least the system is reliable.
I never enable AiProtection so yeah the issue has been happening without AiProtection even.
The best firmware for the AX88U with 0 issues for me is 3.0.0.4.384_9107
Sorry that isn't meant to be a link, try this:
Thanks a lot! Been checking for updates daily and was wondering why they have ignored his router for so long! Let's see how this firmware goes I hope they fixed the random disconnection issues.
I just installed it then reset my router to defaults.
Yeah i noticed because the ASUS Android app highlighted that it was available when i logged on to it. Quite handy.
Good for you. Want a medal?
The point is if something is perfectly stable for one user, and totally unstable for another, then maybe that other user needs to troubleshoot their setup instead of making a blanket statement. Or making snarky remarks.
I have a new AX88U in the mail. So I can join the fun. My other ASUS routers RT68, AC87U and AC86U were all good routers. So I do expect the same performance from the AX88U
So faulty equipment simply doesn't exist? All consumer products from covid China are perfect actually
