I don't really need Smart Connect, I believe, nothing major going on and the laptops downstairs are going fine. Should I turn it OFF or is it being ON without my changing anything, the better option and just leave it as is?
manual band steering.
Perhaps some day when everything else is working perfectly, I'll play with Smart Connect again. But not during AiMesh development.
OE
I used to do that. AiMesh2 solved that problem for me.
You're right, in some scenario it makes sense not to use SC. And in some other cases it's simply annoying to end up in 2.4 on a busy radio.
But in most cases it does makes sense! Especially when devices are having 2 5GHz radios.
With each AiMesh advance, I think about switching SC ON with same SSIDs... mostly to look fashionable because my client use is fine without it. But I figure I'll at least wait until AiMesh 2.0 is released before adding more uncertainty to it... I can wait.
And I have been wondering how SC and WiFi 6e and tri-bands will operate when I get there in a year or two or three... adding more different SSIDs is not fashionable!
Fashion is often not practical... but it's fun.
OE
I can give you an scenario that troubled me all the way since Asus decided to go for dedicated wireless backhaul until AiMesh2.
I'm in Europe so power between channels varies massively. High frequency ones are at 1W but with DFS. And 2.4 is crowded as everywhere else in the world.
My low 5GHz channels are borderline useful in some spots of my place. But required by some devices that are not supporting high 5GHz channels.
One solution would be to define an SSID per channel, so 3 SSIDs. Manually switching when needed.
Another solution would be SC. But I couldn't use high 5GHz in SC because of Asus.
So I had the same SSID for 2.4 and low 5GHz, with SC. And another SSID for high 5GHz. And that gives me higher power, enough to the place I was looking for. But manual selection - otherwise it will go into 2.4 and speed was terrible.
Now, without a "dedicated" wireless backhaul I didn't need, I can use SC on all 3 radios. Technically speaking I'm with the same solution I had 2+ years ago and it just works (granted, I still need to reboot my GT router every 2-3 days for stability reasons, but that's ok, it happens over night so nobody cares about it).
Bonus, guest on nodes, but no playdates so no actual need for it
Thread starter | Title | Forum | Replies | Date |
Advice pls - DSL-AC88u as Adsl bridge into an RT-AX88u | ASUS AC Routers & Adapters (Wi-Fi 5) | 4 | ||
T | Smart Life Device Keeps Disconnecting Daily | ASUS AC Routers & Adapters (Wi-Fi 5) | 1 |
Welcome To SNBForums
