Solved RT-AX88U Per IP monitoring
davlast
is per ip monitoring not supported on the rt-ax88u yet or is there a problem with my firmware
I have the rt-ac88u aswell but its working there fine
It is not supported. It is removed from the newer routers as it is not compatible with them.
P.S. You posted in the wrong sub-forum.
thx for the reply,
Saw after i posted it sorry, cant figure out how to move it to the correct sub-forum
