RT-N16 dual wan IPTW and setting problem
boot
1. I don't want to use load ballancing and want to use just IPTV from second provider. How can I modify settings for this?
2. I have one dinamic and one static ip address on providers. But when I try to change WAN type I see the same settings for both wans. I cann't set one dynamic and one static address.
version 3.0.0.3.178.15
Dual WAN support will be disabled in future RT-N16 builds, since too many issues have been reported specific to that router, and I have no way to troubleshoot it.
Not sure why dualwan issues should be different in N16 vs N66U, but makes sense to concentrate on one you can test - I suspect most issues will be common, and when 'mature' we can flick the compile switch back on. wanduck looks pretty key to overseeing it all.
I wish I knew what were Asus's plans there. The DUALWAN option isn't even listed in the list of build time options, I only know about it because the switch is referenced to all over the code, and when I tried to add it it seemed to work.
I suspect that most issues specific to the RT-N16 have to do with the webui. Some of the pages are different depending on for which router the firmware is being built.
Hello
How does this possibility works now?
I have 2 providers and dual wan enabled.
One provider for internet(Second WAN), one for IPTV(WAN). But they don't want to work together. Only internet or only IPTV.
What changes do I need to perform more?
Version 3.0.0.4_376.48_3
