olblueyez
No Reply From 192.168.1.1
I installed 3.0.0.4.374_979 on my RT-N66R Yesterday.
The Configuration Page was not available via wireless because the page continuously reloaded the login pop up asking for the login info, over and over and over and over,,... To cancel out gives you a 401 error "Not Authorized" on the page. This is via wireless using my BlackBerry.
The Page was accessible via a wired desktop.
3.0.0.4.374_979 <<---IS VERY SLOW and is not just some minor fixes. The UI has been changed and it will "In no way accept and old .cfg file from the last version".
After wasting a big chunk of my weekend screwing around with this new firmware from ASUS I decided to re-install 3.0.0.4.374.720.
(3.0.0.4.374_720) had been very good for me accept one glaring issue. I am unable to access the Configuration Page via my wired desktop. I can however access the config page via wireless on my BlackBerry and it works extremely well. If the problem regarding config page access via a wired desktop were fixed it would be great,,... For my use anyway.
(3.0.0.4.374_979)<<---Slow Performance, (Netgear Slow UI), no config access via wireless.
(3.0.0.4.374_720)<<---Fast Performance, small issue with wired config access.
