Ackhold
Hi All,
This issue is driving me crazy so I'm hoping someone here can help me.
I have an Asus RT-N66U router running the stock firmware (3.0.0.4.380_3831-g93dfe8c) and a Cannon iX6550 which is connected via USB. In the past this worked fine however I recently had to change my router IP from 192.168.1.1 to 192.168.5.1 as I was having problems VPN'ing into my office PC as that is also on a network running 192.168.1.XXX addresses. Now the printer periodically stops working until I reset the router at which point it works again... for a while.
I've been banging my head against the wall with this for a while now so here's what I know...
While troubleshooting the problem I have tried:
Basically I'm pretty sure it's the router that's the problem as doing a power cycle temporarily fixes the issue however I don't know what else to do to confirm this or what to do to get additional information or fix the issue. Any suggestions?
If I can't figure this out is it worth trying the Merlin firmware? otherwise I'm probably going to need to get a separate print server... which I don't have enough ethernet ports for, so I'll need a switch as well, seems like that's an over engineered solution.
Any help or advice would be really appreciated, thanks.
- I am connecting to the printer via LPR as described here https://www.asus.com/support/faq/114024
- After changing the routers IP address I removed the old port that pointer to 192.168.1.1 and created a new one pointing to 192.168.5.1
- If I reset the router it works for a few hours (not sure how long exactly) after that I just get errors when trying to print
- Turning the printer off and on again has no effect, same with PC's and I have this issue on multiple PC's all running Windows 10.
- Router can see the printer and identifies it as the correct make/model and says it's "enabled"
- Updating the router firmware
- Updating the printer driver
- Completely uninstalling the printer drive, removing the port, rebooting the PC and re-adding it all
- Using the other USB port on the router
