ViRtUaLheretic
First off let me say Thank you to this community, I have been trolling for a year or two but just recently became stumped with an issue I am having at work.
Basically the Wireless download speed of our N66U router at work is typically ~3Mbps whereas our wired connection typically gets 12Mbps+ (this is on 2.4 and 5Ghz).
Network Layout:
Dedicated 20/20 Fiber Connection routing to office
Cisco 5510 Firewall (managed by our datacenter provider to provide secure VPN)
RT-N66U
couple of switches going to hardwired machines
seperate dedicated cable connection for VOIP phones
VOIP modem and router
After banging my head on trying out every different options I updated firmware to the latest build and still had the same problem. I then "downgraded" to 3.0.0.4.276 and tried that to no avail.
Every time I flashed a new firmware I did a full reset and reconfigured everything manually from there. Each firmware provides the same slow WLAN download speed. Maybe worth noting is that our upload speed is and has always been fantastic. Speedtest.com always shoots straight up to 20Mbps and can show speeds up to 30Mbps.
Another thing I tried doing was moving the unit from the network closet where it can get pretty hot, to the room outside of the networking closet where it is always cold.
Here is a list of my current configuration of the router:
2.4Ghz:
Wireless mode: auto
Channel 6 (channels 1 and 11 are crowded but 6 is open)
bandwidth 20/40
Extension: auto
Wpa2
Aes
Network key rotation interval: 0
Multicast: disable
Preamble: auto
RTS: 2347
DTM: 3
Beacon: 100
TX Bursting: enable
Multicast: disable
WMM APSD: disable
Enhanced interface management: enable
TX power: 80
5Ghz:
N only
control channel: auto (nobody aroudn here is using the 5Ghz band)
bandwidth: 20
Extension: auto
WPA2
AES
(professional settings are the same as 2.4)
Router is currently set as an Access Point, but have tried Wireless router mode as well with same results.
At this point in time I am thinking that maybe prolonged exposure to heat in the network closet as well as having the TX power adjustment turned up to 100 took its toll on the router and now needs to be replaced?
Ive literally tried changing EVERY single option but cannot seem to get the WLAN download speed to increase over 6Mbps, and this is confirming with 3 different laptops and 2 phones.
As was stated if I hardwire directly into the N66u I can easily pull ~12Mbps down, but only WLAN is slow.
I have searched all over this forum and others but have came up short thus far. I am open to any suggestions. Thanks!
TLDR:
WLAN Download speeds are ~4Mbps, wired download speed is 12MBps+, and have tried 3 different firmwares and every available config option.
Network Layout:
RT-N66U
2.4Ghz:
Wireless mode: auto
bandwidth 20/40
Extension: auto
Wpa2
Aes
Multicast: disable
Preamble: auto
RTS: 2347
DTM: 3
Beacon: 100
TX Bursting: enable
Multicast: disable
WMM APSD: disable
TX power: 80
5Ghz:
N only
bandwidth: 20
Extension: auto
WPA2
AES
TLDR:
