Ferrarista
I have an Asus AX88U Router. Before the last update of the Merlin firmware (388.2_2) I used to have a script running each 3 minutes. Unfortunately, after the firmware update, the script got canceled and I tried to repeat the procedure to have it running. I added it to /jffs/scripts, granted it x permissions and then added to the crontab by copying the following line
The script works fine if I launch it from command line and also the new entry in the crontab appears if I type
Unfortunately, if I reboot the router manually, the crontab is reset to it's initial state and this happens also if I type
after the procedure described above.
*/3 * * * * /jffs/scripts/reboot_script.sh
cru l
nvram commit
