runner mode is disable without touching anything, help please. ax-11000
berku4
Greetings, I need advice with the latest merlin firmware update for my ax-11000. the "runner" mode is deactivated only every few minutes, I activate it through putty but after a few minutes without touching anything it is deactivated. I have tried some scripts to activate the runner but they don't work because it ends up deactivating itself. Can someone write me a script where the runner is not deactivated. I don't know what else to do, thanks. shh script for putty, thanks.
this script no found:
runner enable
nvram set runner_enable="1"
nvram set runner_enable_force="1"
nvram commit
It depends on what firmware options you have enabled. If it gets constantly disabled - it's incompatible with something. You have to describe your configuration first otherwise no one can help you. Forcefully re-enabling Runner is not the solution.
Nothing, everything is well configured. In fact, I just downgraded the firmware and I still have the same problem. I am with adaptive mode of qos. the runner turns off.
I want to reverse the change. I mean, I want to have the runner activated but I can't. Sorry for the inconvenience.
Run these commands to undo the mess you've made and see if it's any better:
nvram unset runner_enable
nvram unset runner_enable_force
nvram unset runner_disable
nvram unset fc_disable
nvram unset runner_disable_force
nvram unset fc_disable_force
nvram commit
service reboot
nvram commit
service reboot
this script no found... it's a very strange thing.
