Associated CVE IDs: None
NETGEAR has released fixes for a pre-authentication buffer overflow security vulnerability on the following product models:
To download the latest firmware for your NETGEAR product:
Security Advisory for Post-Authentication Command Injection on Some Routers and Gateways, PSV-2017-2160
NETGEAR has released fixes for a post-authentication command injection security vulnerability on the following product models:
NETGEAR has released fixes for a directory traversal security vulnerability on the following product models:
- D3600, running firmware versions prior to 1.0.0.67
- D6000, running firmware versions prior to 1.0.0.67
- D7800, running firmware versions prior to 1.0.1.30
- R6100, running firmware versions prior to 1.0.1.20
- R7500, running firmware versions prior to 1.0.0.118
- R7500v2, running firmware versions prior to 1.0.3.24
- R9000, running firmware versions prior to 1.0.2.52
- WNDR3700v4, running firmware versions prior to 1.0.2.96
- WNDR4300, running firmware versions prior to 1.0.2.98
- WNDR4300v2, running firmware versions prior to 1.0.0.50
- WNDR4500v3, running firmware versions prior to 1.0.0.50
- WNR2000v5, running firmware versions prior to 1.0.0.62
- Visit NETGEAR Support.
- Start typing your model number in the search box, then select your model from the drop-down menu as soon as it appears.
If you do not see a drop-down menu, make sure that you entered your model number correctly, or select a product category to browse for your product model. - Click Downloads.
- Under Current Versions, select the download whose title begins with Firmware Version.
- Click Download.
- Follow the instructions in your product’s user manual, firmware release notes, or product support page to install the new firmware.
- Click Download.
- D7000, running firmware versions prior to 1.0.1.60
- D7800, running firmware versions prior to 1.0.1.34
- D8500, running firmware versions prior to 1.0.3.39
- R6700, running firmware versions prior to 1.0.1.30
- R6700v2, running firmware versions prior to 1.2.0.16
- R6800, running firmware versions prior to 1.2.0.16
- R6900, running firmware versions prior to 1.0.1.30
- R6900P, running firmware versions prior to 1.2.0.22
- R6900v2, running firmware versions prior to 1.2.0.16
- R7000, running firmware versions prior to 1.0.9.12
- R7000P, running firmware versions prior to 1.2.0.22
- R7500v2, running firmware versions prior to 1.0.3.20
- R7800, running firmware versions prior to 1.0.2.44
- R8300, running firmware versions prior to 1.0.2.106
- R8500, running firmware versions prior to 1.0.2.106
- D8500, running firmware versions prior to 1.0.3.35
- R6250, running firmware versions prior to 1.0.4.14
- R6900P, running firmware versions prior to 1.0.0.62
- R7000P, running firmware versions prior to 1.0.0.62
- R7900, running firmware versions prior to 1.0.2.8
- WNDR3400v3, running firmware versions prior to 1.0.1.14
- WNR3500Lv2, running firmware versions prior to 1.2.0.48
