I just discovered that when I enable web access to router settings from Wan, using default port 8080 and asus DDNS service, the router does not use the authentication, it allows you enter to the settings directly.
Fron inside my lan, on the other side, it asks for user and password.
I have the rmerlin 374.35_4 version installed
Also have entware installed lighttpd with PHP following this guide guide
I will investigate when I return home if it is related to lighttpd, to entware, to the firmware, to the modifications made on firewall-start or may be in the port forwarding.
If I get some hint, I will post it here. For the moment, I have unticked the option for remote administration on the 8080 port.
---update---
RMerlin is right, it was a cached credentials problem
I enabled again web access from WAN and the tryed from another machine and the login prompt was shown.
---update---
