386.11 Firmware - openvpn-client: --script-security message every 30 seconds
salieri
Router = RT-AC86U
I've upgraded its firmware from 386.10 to 386.11. Haven't changed anything on my side and now I'm getting this message every 30 seconds:
ovpn-client1[18938]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Is there something I need to do to fix this message from occurring? If not, how do I suppress it? My log verbosity is already set to 0.
Thanks.
That's a fairly normal message. It's just a warning that should only appear once at startup. If your VPN client is restarting every 30 seconds then you need to look for the actual error that's causing it. For example:
