Setting ASUS DSL-N17U and RT-AC68U in Bridge Mode
Turgut Kalfaoglu
Hi.. My DSL-N17U has been working as a stand-alone modem/router and doing a lot of the work.. Just behind it, there is a RT-AC68U that's running Merlin.
The RT-AC68U does the LAN DHCP, and most of the routing/etc. This has been working fine, with DSL-N17U doing the PPPoE, 802.1Q enabled, on VDSL2 LAN PTM.
I thought I would switch the N17U to the Bridge mode because currently, I had to double-NAT and it's ugly and wasteful..
So, tried to set my DSL-N17U and the AC68U in Bridge mode..The two devices are connected via ethernet obviously.
However it never works.
On the N17U, setting the bridge mode is done, LAN port 1 selected..
I then went into RT-AC68U and changed the connection from Static IP to PPPoE, entered username and password.. Hit save.. I verified that I used the correct username/password.
However the RT-AC68U never shows a connection.. I'm using Turkish Telecom, TTNET..
I also couldn't find anything in the log files either, about what PPPoE was doing, and if it could connect to the remote site, etc..
Any ideas how to get the Bridge mode working?
Many thanks!
-t
I do not believe then bridge mode, as described in the Asus manual, will work for you. The DSL-N17u's bridge mode is a wireless feature called Wireless Distribution Mode which is an old method to set up WIFI repeaters. Your best bet is to get a DSL modem and set that up before the AC68U.
I tried ASUS's recommendation, and the PPPoE still did not connect. I also couldn't find a log file detailing its handshake.. So I can't tell why it failed..
SUCCESS -- I don't know what I changed -- but THIS time, it worked.. The N17U is running in BRIDGE mode (they uppercased it in settings, lol), and the AC68U is running PPPoE..
BTW, If you ever need to access the ASUS DSL-N17U in Bridged mode (like to see the line characteristics, etc), simply plug an ethernet to the 3rd port of the modem. It even still has a DHCP server running.. very convenient :)
Hi there. About accessing the DSL-N17U to see the DSL connection status etc, you said "simply plug an ethernet to the 3rd port of the modem". As in, use your laptop to connect to the DSL-N17U itself via ethernet? Or do you connect it to your router's LAN ports and it's being treated like a client?
Just plug in your laptop. But in the long run I found it's easier to just leave its Wi-Fi enabled so that I can access it from my laptop. That way you have an access point that cannot reach the internet but has the modem interface
Oh, that was what I feared 🫠 I genuinely don't want to have another 2.4G network being broadcast next to my main one. And I was hoping to be able to access the web interface from my local network and leave the modem under the cabinet, never to be seen 🫠
Oh, I set its wifi power to 10% :) So the range is very limited..
