Hello
I don't expect or think anything major might happen, it's already working in my test case here. The ATL LTE18 is a Cellular client antenna and modem that converts the 3G/LTE signal to a wired Ethernet connection.
However it's the first time I'm dealing with anything Mikrotik or Router OS in general.
I remember loosely reading on this forum something about "router.lan" being a problem, but I can't find the post now. I think one of the addon or FW developers mentioned it.
Now several days into setting up the Mirkotik ATL antenna, I came across a default configuration that mentions "router.lan" and I'm wondering if that could cause problems down the line with the Asus router and DNS, eventually Diversion?
Exporting the entire config mentions this:
BTW: It's a long story tho, don't get me started hehe, I had no idea the ATL LTE18 was a full blown router as well, but oh well, you can't run diversion and other stuff on it ofcourse, it may just have it's own way of doing just that, it's for a remote location and due to FTTH being setup with all new modems at the primary location, the router was upgraded too, leaving this spare, so it's all fine.
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan
