Simple script not launching on boot
SwizItalo
  • So i made a script at "/jffs/scripts" (the folder scripts wasnt there, so i made it)
  • Enabled JFFS custom scripts and configs on webui
  • chmod 777 file services-start
  • The script runs ok when i manually execute it "/jffs/scripts# sh services-start" but it won't launch on start up
This is content:
#!/bin/sh
sleep 20
# Wifi On
nvram set wl0_radio=1
nvram set wl1_radio=1
service restart_wireless
# Linksys logo
/jffs/bin/gpio 6 0
When i run it manually it says :
'leep: invalid number '20
But the script runs fine, except the sleep command is wrong? and dont have time to execute the next commands in the moment of startup?
By the way, i don't understand why the error says 'leep and no sleep
This is content:
#!/bin/sh
sleep 20
# Wifi On
# Linksys logo
/jffs/bin/gpio 6 0
Are you still using illegal firmware on a Linksys ea6900? If so, that might be your problem.
That folder is always there with genuine Merlin firmware. Another indication that there's something amiss with the firmware that you're using.
If the folder isn't there, then you aren't running Asuswrt-Merlin, or are on a version that is many years old and probably doesn't support user scripts.
I found a solution:
I remove the services-start i created and start over.
First install scMerlin and edit services-start already generated by the addon.
