I use RT-AC66U_B1, and it's device name is RT-AC66U_B1-2808 in webui samb setting page. After upgrade to 384.15, netbios name was changed from RT-AC66U_B1-2808 to RT-AC66U_B1-280.
How to fix this ?
thanks a lot for any help.
384.14-2What was the version of the previous firmware you had?
I didn't set Device Name in that tab, it was autogen by the sysytem. The value is RT-AC66U_B1-2808.Can you not set the Device Name on the Network Place (Samba) Share / Cloud Disk tab under USB Application?
I tried to change the device name on the Network Place (Samba) Share / Cloud Disk tab, as you mentioned only 15 characters can be filled in.The maximum length a NetBIOS name can be is 15 characters. The input field on the Samba page will not accept any more than that.
It's sounds like that when the router was first setup it didn't truncate the auto-generated name (<model number> "-" <last 2 octets of MAC address>) from 16 to 15 characters as it should have.
I upgrade from 384.14-2 to 384.15, after that i didn't erase the config.Well I don't know how you ever managed to have a device name of 16 characters. Obviously the name was auto-generated like that but I've checked the source code all the way back to the initial 384 release and that field has always been restricted to 15 characters.
Oh well, best to give it a valid name now that you've discovered it.
I appreciate that. I'm just saying that I'm surprised that it ever stored a 16 character name, regardless of what firmware you're using. AFAIK you'd have to go all the way back to a 380.x release for that to be possible.I upgrade from 384.14-2 to 384.15, after that i didn't erase the config.
The last erase config was about half years ago.
Not sure if it's relevant, just thinking out loud.I appreciate that. I'm just saying that I'm surprised that it ever stored a 16 character name, regardless of what firmware you're using. AFAIK you'd have to go all the way back to a 380.x release for that to be possible.
As previously explained the NetBIOS must be 15 characters or less. You can change it on the "USB Application - Network Place (Samba) Share / Cloud Disk" page.I have erase nvram and make a clean starup. I still got a netbios name "RT-AC66U_B1_280".
How can I change netbios name?
ok, i will try to change it.As previously explained the NetBIOS must be 15 characters or less. You can change it on the "USB Application - Network Place (Samba) Share / Cloud Disk" page.
Welcome To SNBForums
