snmpd crash on RT-AX88U
corgan2222
Hello
im using the latest 384.10_2 with entware on a RT-AX88U Router and trying to run a snmpd Server.
Installed using #opkg install snmpd snmpd-utils
Configfile:
/jffs/configs/snmpd.conf:
agentAddress  udp:161
createUser admin
rwuser admin noauth
com2sec public default public
group public v1 public
group public v2c public
group public usm public
view all included .1
access public "" any noauth exact all all all
sysservices 78
start with
#snmpd -c /jffs/configs/snmpd.conf
then the router crashed and reboots.
Any Ideas?
LOG H LOG BEGINNING...
Kernel panic - not syncing: Fatal exception
CPU0: stopping
CPU: 0 PID: 0 Comm: swapper/0 Tainted: P D O 4.1.51 #4
Hardware name: Broadcom-v8A (DT)
Call trace:
[<ffffffc000087658>] dump_backtrace+0x0/0x150
[<ffffffc0000877bc>] show_stack+0x14/0x20
[<ffffffc000527598>] dump_stack+0x90/0xb0
[<ffffffc00008df10>] handle_IPI+0x190/0x1a0
[<ffffffc000080c68>] gic_handle_irq+0x88/0x90
Exception stack(0xffffffc00070bd70 to 0xffffffc00070bea0)
bd60: e792b74c 0000000e 00000000 00000080
bd80: 0070bec0 ffffffc0 0037992c ffffffc0 e792b74c 0000000e 78000000 0021b4d9
bda0: 00034aa2 00000000 14000000 00000000 0001a0e8 00000000 00000018 00000000
bdc0: d0000000 00217304 00ad519c 0000000f 0071a8b0 ffffffc0 0070be70 ffffffc0
bde0: 00000000 00000000 00000000 00000000 00000000 00000000 0071e038 ffffffc0
be00: 0071e098 ffffffc0 00000000 00000000 00145730 ffffffc0 00000000 00000000
be20: 00000000 00000000 e792b74c 0000000e 3ffb72f8 ffffffc0 00000001 00000000
be40: 00000001 00000000 e78f66dc 0000000e 00708000 ffffffc0 0084e000 ffffffc0
be60: 00703000 ffffffc0 3ffb72f8 ffffffc0 007416b0 ffffffc0 0070bec0 ffffffc0
be80: 00379924 ffffffc0 0070bec0 ffffffc0 0037992c ffffffc0 60000145 00000000
[<ffffffc000083f00>] el1_irq+0x80/0xf8
[<ffffffc000379a30>] cpuidle_enter+0x18/0x20
[<ffffffc0000c652c>] cpu_startup_entry+0x1ec/0x250
[<ffffffc000522218>] rest_init+0x88/0x98
[<ffffffc0006cc970>] start_kernel+0x394/0x3a8
CPU3: stopping
CPU: 3 PID: 0 Comm: swapper/3 Tainted: P D O 4.1.51 #4
Call trace:
Exception stack(0xffffffc00dfd7dc0 to 0xffffffc00dfd7ef0)
7dc0: e792b74c 0000000e 00000000 00000080 0dfd7f10 ffffffc0 0037992c ffffffc0
7de0: e792b74c 0000000e 78000000 0021b4d9 00034aa2 00000000 14000000 00000000
7e00: 0001a0e8 00000000 00000018 00000000 d0000000 00217304 00aa72d8 0000000f
7e20: 0dfc3070 ffffffc0 0dfd7ec0 ffffffc0 00000000 00000000 0053a548 ffffffc0
7e40: 000049c9 00000000 ffc114c0 00000000 000189dc 00000000 00000000 00000000
7e60: 0013ece8 ffffffc0 00000000 00000000 00000000 00000000 e792b74c 0000000e
7e80: 3ffe42f8 ffffffc0 00000001 00000000 00000001 00000000 e7882f84 0000000e
7ea0: 0dfd4000 ffffffc0 0084e000 ffffffc0 00703000 ffffffc0 3ffe42f8 ffffffc0
7ec0: 007416b0 ffffffc0 0dfd7f10 ffffffc0 00379924 ffffffc0 0dfd7f10 ffffffc0
7ee0: 0037992c ffffffc0 60000145 00000000
[<ffffffc00008d990>] secondary_start_kernel+0x150/0x178
CPU2: stopping
CPU: 2 PID: 230 Comm: bcmsw_rx Tainted: P D O 4.1.51 #4
Call trace:
Exception stack(0xffffffc030283370 to 0xffffffc0302834a0)
3360: 00000000 00000000 00000000 00000080
3380: 302834c0 ffffffc0 0052bf88 ffffffc0 fc2c4698 ffffffbf 00000140 00000000
33a0: 00000869 00000000 00b80000 ffffff80 00b80000 ffffff80 00000140 00000000
33c0: fc2c4814 ffffffbf fc2c4810 ffffffbf fc2c4800 ffffffbf fc2c47f8 ffffffbf
33e0: fc2c55a0 ffffffbf 0000ac68 00000000 fc2c4830 ffffffbf 00bdac60 ffffff80
3400: 00000150 00000000 32700000 ffffffc0 00000001 00000000 00000001 00000000
3420: 00000000 00000000 00000000 00000000 00000000 00000000 460000b0 00000000
3440: 0000000d 00000000 fc2c4818 ffffffbf 00000046 00000000 00000000 00000000
3460: 0005ac60 00000000 00000000 00000000 fc2c4698 ffffffbf 302834c0 ffffffc0
3480: fc1989b8 ffffffbf 302834c0 ffffffc0 0052bf88 ffffffc0 80000145 00000000
[<ffffffbffc1989b8>] rdpa_cpu_tx_port_enet_or_dsl_wan+0x3c0/0x8d0 [rdpa]
[<ffffffbffc165254>] rdpa_cpu_tx_port_enet_or_dsl_wan+0x14/0x28 [rdpa_gpl]
[<ffffffbffc412bc4>] dispatch_pkt_gbe_wan+0x2c/0x68 [bcm_enet]
[<ffffffbffc40dac8>] enet_xmit+0x300/0x5f0 [bcm_enet]
[<ffffffc0003dda54>] dev_hard_start_xmit+0x9c/0x3a0
[<ffffffc000402c30>] sch_direct_xmit+0x108/0x238
[<ffffffc000402dbc>] __qdisc_run+0x5c/0xe0
[<ffffffc0003ded20>] __dev_queue_xmit+0x2a0/0x558
[<ffffffc0003defec>] dev_queue_xmit_sk+0x14/0x20
[<ffffffc00044e730>] ip_finish_output+0x248/0xa28
[<ffffffc000450820>] ip_output+0x130/0x160
[<ffffffc00044fecc>] ip_local_out_sk+0x3c/0x48
[<ffffffc0004501d8>] ip_queue_xmit+0x118/0x348
[<ffffffc000466c80>] tcp_transmit_skb+0x400/0x9d0
[<ffffffc000468958>] tcp_send_ack+0x118/0x170
[<ffffffc00045ca94>] __tcp_ack_snd_check+0x5c/0x98
[<ffffffc0004639f8>] tcp_rcv_established+0x1d0/0x6f0
[<ffffffc00046bf00>] tcp_v4_do_rcv+0x170/0x3c0
[<ffffffc00046e724>] tcp_v4_rcv+0x8d4/0x948
[<ffffffc00044a2ec>] ip_local_deliver_finish+0xd4/0x250
[<ffffffc00044a970>] ip_local_deliver+0xc8/0xe0
[<ffffffc00044a59c>] ip_rcv_finish+0x134/0x320
[<ffffffc00044ac58>] ip_rcv+0x2d0/0x3b0
[<ffffffc0003d91b8>] __netif_receive_skb_core+0x740/0xa20
[<ffffffc0003dc2c4>] __netif_receive_skb+0x2c/0x88
[<ffffffc0003dc360>] netif_receive_skb_internal+0x40/0xc0
[<ffffffc0003dc3f0>] netif_receive_skb_sk+0x10/0x18
[<ffffffbffc40ebe4>] chan_thread_handler+0x5c4/0x840 [bcm_enet]
[<ffffffc0000af090>] kthread+0xd8/0xf0
snmpd is not compatible with the RT-AX88U, this is why I don't enable that feature in my firmware.
You can't. As I wrote, is not compatible with that router. It crashes trying to poll the network switch.
Sent from my ELE-L04 using Tapatalk
did you changed that in the last update?
I disabled net-snmp months ago because it was crashing, so it's nothing new. The same issue also existed with the RT-AC86U before the RT-AX88U got released.
It's not something that "I changed" either, it's simply not compatible with the closed source components from Broadcom.
Whats about the Entware "libnetsnmp" Package? Did this have the same problem?
No idea, I only tested net-snmp.
I assume this is still an issue since the SNMP tab is not present in the RT-AC86U Web GUI? Has this been tested recently with net-snmp and has the issue been raised with net-snmp?
Thanks!
