simistef
I am trying to setup different SSIDs for VPN as per wiki tutorial here: https://github.com/RMerl/asuswrt-me...or-VPN-and-SSID-for-Regular-ISP-using-OpenVPN.
Managed so far to:
- succesfully created an OpenVPN Client 1 connection and tested that runs ok
- create vpn_ssid file inside /jffs/scripts folder
- create services-start file inside /jffs/scripts folder to run the vpn_ssid file
- made scripts executable by running command : chmod a+rx /jffs/scripts/*
- the optional part of the tutorial skiped
After restarted the router and tried to open the OpenVPN Client 1 connection, it just does not work, giving me an error in the system logs:
Aug 5 20:57:31 rc_service: httpd 500:notify_rc start_vpnclient1
Aug 5 20:57:35 openvpn[1505]: Options error: You must define CA file (--ca) or CA path (--capath)
Aug 5 20:57:35 openvpn[1505]: Use --help for more information.
Any ideas what i am missing here ?
Thanks in advance.
Managed so far to:
Thanks in advance.
