PinkFloydEffect
I bought an "Eliminator" E107 control center for my rack, it is just 8 power switches with 8 separate outlets so you can cycle power for individual components in your rack. There is not power conditioning, or surge protection, it only has a simple breaker.
Before I purchased the power center switch panel I already had ordered a TrippLite Isobar to protect the rack. Now I am not sure what to do, the Isobar claims to have isolated outlet banks. To me this sounds like it keeps the components you have plugged in isolated from each other in event of a problem, if the source of the problem was something you have plugged in and not coming from the power source or grid it would give you a layer of protection.
Sure I could plug the power center switch panel into the Isobar using only one single outlet but I would not be utilizing the isolation feature right? I am not sure if the full capacity of the Isobars surge suppression would be utilized in this way either, having my entire rack running off a single plug on the Isobar?
Should I ditch the Isobar for another surge/conditioner that has single input and single output with no power strip built in? I am really confused on what direction to take.
