Thinking about coming back to the AC68U.. advise please.
TomT
Hi
I've got a fully working AC68U that I stopped using and started using pfSense.
I'm having a few issues with connectivity so think I may try running from the AC68U for a week or so, before I do this I have a few questions.
1. Which version of merlin show I run for the best reliability, stability and connectivity.
2. Does the AC68U support IPSEC & OPenVPN, can they both be active at the same time ?
2a. For IPSEC can I limit what traffic is allowed to route across this ?
2b. For openVPN can I set specific devices to use this as there default gateway ?
3. Can the wireless be disabled ?
Thanks for your advise :)
The RT-AC68U does not support IPSEC, due to kernel restrictions.
Thanks. Unfortunately I need IPSEC connectivity to the office.
If I use open VPN can I setup multiple and specify which devices are allow to route out of each ?
Yes, you can. They will need to be setup as static IP's in the LAN tab, but it does work.
Yes, provided you run a custom firmware that supports it - stock firmware doesn't.
