Todo after upgrade firmware?
johndoe85
Is it mandatory or good practise (atleast) if you will, that you reset nvram after a firmware upgrade? From 384.19 to 386.1 for example?
Is it worth saving the settings in such a case? Or is it countraproductive to the nvram flash?
Current discussion:
OE
Heh, i did search before posting, not for reset though but flash nvram.
The post you linked is not old either.. how about that? :D
I do have one question to that FAQ list.
Why does not the new firmware always reset nvram once it's flashed? Or atleast give me an option to do so, and save me some time.
Because when the router boots, it has no way of knowing if it should do a reset or not. And also because in the vast majority of cases a reset is NOT required.
