I had a disk that started to report SMART errors on my regular SMART checks. So I swapped it out (cold - powered down) and booted. The array rebuilt after several hours OK (according to the logs). But no mount.
I have checked the array with e2fsck and all seems OK. I can also mount it in a arbitrary directory. But no shares.
Any ideas?
EDIT:
I mounted /dev/md0 in the MD0_DATA directory and shares now appear - who hoo. But this is only a temporary solution. Running init_disk (which I believe it does at boot up) fails to mount the array.
Any ideas?
EDIT:
