uiDivStats uiDivstats 4.0.14 - WebUI Stats for Diversion
thelonelycoder
Part of the Furniture
This is a fork of uiDivstats development version by @Jack Yaz . The changes are compatible to upstream with the exception of the repository path.
This fork is hosted at my GitHub account.
Just a little thing. I have 4.0.0 installed, confirmed by the amtm menu. If I then check for updates again in amtm I get:
Yep, 4.5. Updated amtm first.
I cannot reproduce this. What's the header of j5 uiDivStats displaying for the version?
Yes, only when checking for other updates in amtm with "u".
I see, this appears to be a firmware beta glitch. Let me check what's going on.
same thing here, no backupmon installed
_____________________________________________
 The current release of uiDivStats (4.0.0) is
 no longer compatible with Diversion 5.1.2.
 Watch out for an update with  u  in amtm,
 it will show when a new version is available.
Same thing happened to me.
I ran option 'j5u' in amtm.
Gave me the following message:
You already set to use the uiDivStats
version by thelonelycoder.
Re-ran amtm and j5 option was correctly shown !!!???
Rebooted the router and the same error trying an update in amtm with "u". "j5" loads the addon just fine.
I'm gonna reset the router and try from scratch.
Yeah not working for me either but different. amtm 4.5 updated, even did a 'reset amtm'.
There's no "j5u" option.
j5 launches 3.0.2.
Trying j5u anyway gets...
Let me sleep over this, I need some time to ponder my over-complicated code 😴
It'll get sorted out in the next few days.
And maybe a beer or two might help...
Yeah, you deserve a break the work you've done lately 👍
