[UK] Asus 4G-AC68U router, constantly dropping connection on EE mobile network?
wild4gwonderer
Hi all,
I recently decided to give up fixed line ADSL as I will be travelling around the UK a lot.
After doing some research into 4G Wireless routers, I settled with the ASUS 4G-AC68U partly because it looks cool and also due to its WIFI antenna ranges.
Initial testing of the router was done with a pay as you go (PAYG) sim card on MVNO network, this was simple to setup and it autoconfigured the APN. I did not experience any drops in internet connection.
So I decided to go with an EE sim with plenty of data. I immediately noticed the speeds were faster, however the WAN connection keeps dropping.
Here are some logs over 2minutes showing you it dropping connection twice
Sep 21 14:57:56 WAN Connection: ISP's DHCP did not function properly.
Sep 21 14:57:56 rc_service: wanduck 182:notify_rc stop_wan_if 0
Sep 21 14:57:57 nat: apply redirect rules
Sep 21 14:58:00 WAN Connection: Ethernet link down.
Sep 21 14:58:08 kernel: cdc_acm 2-2:1.2: This device cannot do calls on its own. It is not a modem.
Sep 21 14:58:08 kernel: cdc_acm 2-2:1.4: This device cannot do calls on its own. It is not a modem.
Sep 21 14:58:08 hotplug: add net usb0.
Sep 21 14:58:09 hotplug: Got net usb0, vid 0x5c6, pid 0x9026.
Sep 21 14:58:09 hotplug: set net usb0.
Sep 21 14:58:17 WAN Connection: Ethernet link up.
Sep 21 14:58:17 rc_service: wanduck 182:notify_rc restart_wan_if 0
Sep 21 14:58:37 WAN Connection: ISP's DHCP did not function properly.
Sep 21 14:59:20 nat: apply nat rules (/tmp/nat_rules_usb0_usb0)
Sep 21 14:59:21 wan: finish adding multi routes
Sep 21 14:59:22 WAN Connection: WAN was restored.
Sep 21 14:59:23 dnsmasq[543]: nameserver 109.249.185.228 refused to do a recursive query
Sep 21 14:59:26 miniupnpd[13143]: shutting down MiniUPnPd
Sep 21 14:59:27 miniupnpd[3899]: version 1.9 started
Sep 21 14:59:27 miniupnpd[3899]: HTTP listening on port 45612
Sep 21 14:59:27 miniupnpd[3899]: Listening for NAT-PMP/PCP traffic on port 5351
Sep 21 14:59:54 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Sep 21 14:59:54 BWDPI: fun bitmap = 47f
Sep 21 14:59:55 nat: apply nat rules (/tmp/nat_rules_usb0_usb0)
Sep 21 14:59:56 dhcp client: bound 100.66.250.160/255.255.255.255 via 100.66.250.160 for 7200 seconds.
Sep 21 15:00:12 dnsmasq[543]: nameserver 109.249.185.229 refused to do a recursive query
Here are my settings
Things I have done:
  • Upgraded the firmware
  • Tested a different 4G sim, it was stable and ok
  • Checked the signal, full strength and line of sight with transmitter
  • Posted here for help!
Any ideas, I will contact EE potentially to see if there are specific configurations to be done.
with your EE sim - you need to confirm the APN values, don't use auto, as the SIM may not have the APN's pre-programmed.
The cdc-wdm warnings - likely the 4g modem itself is resetting, hence you see hotplug eventually picking the interface back up...
