Updated to 384.19 and cannot login
JHZR2
I was messing with router settings on my mesh setup (AX58U main, AX56U node), and updated to 384.19 on the AX58U (left the AX56 with 384.18, as a newer version isn’t available).
I’m not able to login through router.asus.com anymore. Usually it hangs and never loads the login, but occasionally it does show the login screen, and then it hangs when a username and password is entered.
Not sure what happens with this - if it’s due to having two different routers, two different firmware, or what.
I’m tempted to hard reset one or both routers, but think that’s a risk. All internet connections, WiFi and wired, all work despite the login issue.
Thoughts/recommendations?
Thanks!
Have you tried clearing the browser cache?
Leave the power switch on (AX58U) and pull the power plug. Wait 1 min, then plug it back in.
I'm having issues as well on my AX88U ... was running perfectly fine on .18, but now after updating to .19, the UI is locking up almost immediately after rebooting it and and completely unavailable after that until I reboot again. Luckily, internet is working fine, but something is very wrong. I even formatted my JFFS partition and restored from backup, to no avail.
Here's what's using up CPU constantly with the new verison:
yes I did.
that is how I typically reboot these when they get stuck. I do schedule them to auto-reboot every day as well.
Found this post, explaining the issue: https://www.snbforums.com/threads/t...-openvpn-test-builds.65323/page-2#post-604325
It finally stopped going after an hour or so, and the UI works again. Seems strange it would take so long and even stranger that the UI would not work, you'd think it would have a higher priority?
This must be the case with mine. But it must also be new with the .19 firmware (for the AX58U at least). I could immediately boot in with the .18 firmware.
I had the same issue. Waited about 15 minutes and I could log in. Everything else seems to work fine so not too worried about it.
