Hi All,
I've come across an odd problem. I have a Virtual Box running on my HTPC, the guest OS is running in Bridged mode, which has previously and still should be treated by the router as a completly seperate device. With it's own IP and its own MAC address. The router shouldnt know that the Guest OS is connecting though the Host.
But it does! (see attache screens)
Before this issue started I assigned both devices static IP's within the router config. Both devices are still assigned the correct static IP's when connecting to the router. The internet connection is sometimes dropped on the Guest and this can only be resolved by a router restart.
This is causing a couple of problems.
1. I can't view both devices in the router interface.
2. I can't select the device from the port forwarding drop down. The ports are still specified however as the port forward was setup prior to this issue occouring.
2. The device that is showing is displayed incorrectly. 192.168.0.4 is actually named HTPC. The guest OS is called HTPC-Downloads.
3. I can no longer connect to the guest OS via port forwarding (from outside the network). RDP, Pulseway etc no longer work.
I've explored all options around the issue being related to Virtual Box and have come out empty handed which only leaves the router configuration/bug.
Router is running 378.52_2
Any ideas?
Any ideas?
