Parallax Abstraction
Hey all. I've been a happy user of Merlin on mt RT-AC3200 for a while now. However, a random problem has popped up and I'm not sure why.
I have VoIP service through my ISP (Start.ca) that I don't use often but when I do, I use the Zoiper5 softphone. It's worked well for a long time but recently, it would always time out when I tried to use it. I called Start.ca and they had me try an alternative server and finally, trying with the GrandStream Wave app on my Android phone. They also didn't work but, as soon as I put my Android on mobile data, it connected immediately. We then bypassed the router and plugged my desktop PC straight into the modem and once again, it worked right away.
I don't have much in the way of custom settings on my router. I have a port forward open that doesn't conflict with the VoIP port (5060) and also run an OpenVPN server on the router, which I've been using since well before this issue came up. That's kind of it honestly. I do live streaming and a bunch of other heavy lifting on my connection and nothing else is acting up at all.
I'm just wondering if anyone else has seen this or knows what settings could be causing the issue? My ISP and I have clearly identified the router as the issue here. Before I screenshot all my settings and factory reset the unit, I wanted to ask here first.
Thanks so much!
Thanks so much!
