WANFailover WAN Failover v2.2.1 Release
Ranger802004
WAN Failover is designed to replace the factory ASUS WAN Failover functionality, this script will monitor the WAN Interfaces using a Target IP Address and pinging these targets to determine when a failure occurs. When a failure is detected in Failover Mode, the script will switch to the Secondary WAN interface automatically and then monitor for failback conditions. When the Primary WAN interface connection is restored based on the Target IP Address, the script will perform the failback condition and switch back to Primary WAN. When a failure is detected in Load Balancing Mode, the script will remove the down WAN interface from Load Balancing and restore it when it is active again.
Requirements:
- ASUS Merlin Firmware v386.10 or higher
- JFFS custom scripts and configs Enabled
- Dual WAN Enabled
- ASUS Factory Failover Disabled (Network Monitoring Options, Allow Failback Option under WAN > Dual WAN)
Installation:
amtm
or
Command Line:
/usr/sbin/curl -s "https://raw.githubusercontent.com/Ranger802004/asusmerlin/main/wan-failover.sh" -o "/jffs/scripts/wan-failover.sh" && chmod 755 /jffs/scripts/wan-failover.sh && sh /jffs/scripts/wan-failover.sh install
Updating:
Use Menu Option 6 or Run the Following Command
/jffs/scripts/wan-failover.sh update
Uninstallation:
Use Menu Option 4 or Run the Following Command
/jffs/scripts/wan-failover.sh uninstall
Link to Script:
Readme:
https://raw.githubusercontent.com/Ranger802004/asusmerlin/main/wan-failover-readme.txt
Release Notes:
v2.2.1:
Deprecated:
- Deprecated firmware version check for compatibility with WAN Failover.
Enhancements:
- Interface status will display as Unplugged accordingly on status console.
- Updated From Address email field to display WAN Failover instead of the to address.
- Added To Name field from amtm email configuration.
v2.2.0:
Enhancements:
- Support for 3006 Codebase
- Support for 388.9
- Added PINGTIMELOGGING configuration option, this option allows ping time logging to be enabled or disabled. Default: Enabled
- Added new Dev Mode to support disabling update channels.
Fixes:
- Fixed an issue where WGSERVERS parameter was causing script to hang during failover events.
- Resolved an issue where RECURSIVEPINGCHECK loop would prevent WAN restart actions to occur.
- Credit for identifying issue: https://github.com/Tigger2014 & https://github.com/nathan57971
- Removed use of pstree to detect and kill PIDs for WAN Failover due to inconsistencies with use.
Known Issues:
- LED service is not restarted in 3006 Codebase during WAN Failover events.
v2.1.3:
Enhancements:
- Added FAILBACKDELAYTIMER configuration option
- Failovers will now restart WireGuard Server instances
Fixes:
- In some cases, the router will have issues restarting a WAN interface. When this condition is detected, the router will automatically be rebooted.
v2.1.2:
Enhancements:
- General optimization
- Added 388.7 to supported firmware list
- Added 388.8 to supported firmware list
- Cron Job will now dynamically be created / removed to prevent continous attempts at running WAN Failover while it is active. When WAN Failover is killed and SCHEDULECRONJOB is set to Enabled it will be recreated on exit.
- Capture mode will output the capture file created when exited.
Fixes:
- General bug fixes
v2.1.1:
Enhancements:
- Added 388.5 to supported firmware list.
- Added 388.6 to supported firmware list.
- Added configuration option to perform a conntrack flush during failover.
Fixes:
- Updated logic for IPv6 Address data collection.
- The default rules created by the firmware will be deleted if a custom load balancing rule priority is configured.
- OpenVPN Clients will be restarted during failover events.
- Null values for WAN Web GUI IP Addresses are now valid.
v2.1.0:
Enhancements:
- Added WAN0 and WAN1 Web GUI configuration options to create routes for the device portals for each WAN interface.
- Added Reset Default Configuration to Configuration Menu, additionally the command argument resetconfig can be used.
- Enhanced uninstallation prompt for verifying to uninstall.
Fixes:
- Fixed an issue where update would hang if WAN Failover wasn't running.
- Fixed an issue that would allow Load Balance FWMarks and Masks to be non-hexidecimal values in console.
- Added function to verify reverse path filtering is disabled after restarting WAN interfaces and when performing initial WAN Status checks. This is already disabled by the firmware by default but automatically re-enables when an interface is restarted and can cause issues with the target IP rules.
v2.0.7:
Enhancements:
- Added metric values to IP Routes created for target IPs.
- Added additional debug logging to WAN Switch function.
- Added 386.12 to supported firmware list.
- Minor optimizations to increase performance.
- Added CRLF argument to email.
- Added restart option to Status Console.
- Major performance optimization for NVRAM Check function.
- Parent PID is now displayed on Status Console with Dev Mode enabled.
- Added error message if an invalid run argument is specified.
- Added Failover timeout setting. Default is 30 seconds
Fixes:
- Minor visual bug when WAN Failover kill command is being executed.
- WAN Failover will go to disabled state now if DNS Query or Failback are checked under Dual WAN Settings.
- Fixed issue causing PID File not to be deleted under /var/run/wan-failover.pid
- Failover will now properly timeout when the 30 second timeout timer has been reached.
Install:
- Warnings for DNS Query or Failback being enabled will now alert and log during installation
Deprecated:
- WAN0 Route Table and WAN1 Route Table configuration options have been deprecated and are now pulled directly from the Route Table file.
v2.0.6:
Enhancements:
- Added 388.4 to Support List
- General Optimization
- WireGuard clients will restart during failover to recreate the default routes in each WireGuard Route Table.
Fixes:
- Corrected issue where having no OpenVPN Server Instances configured caused WAN Failover to hang.
v2.0.5:
Fixes:
- Corrected minor issue when retrieving WAN NVRAM Parameters
- Corrected issue if WAN Failover would be stuck in a continuous loop if a router didn't have WAN USB capability.
- Corrected issue that causes WAN Failover to exit in Load Balance mode during failover events.
- Corrected issue where DDNS Hostname being blank would cause the script to hang in a loop while collecting System Settings.
- Corrected issue during install where the existing monitor target value was a domain and being used as the WAN0 Target IP default value.
v2.0.4:
Enhancements:
- Added 3rd DNS Server from Automatic Settings to be factored into WAN Failover events.
- The checkiprules function will now be checked at the beginning of WAN Status checks to ensure NAT rules are created if necessary prior to performing packet loss checks.
- Added 386.10 and 386.11 to supported firmware list
- Removed 386.5 and 386.7 from supported firmware list.
Fixes:
- Corrected issue during uninstall when logic was reversed for retaining configuration file or to delete.
v2.0.3:
Fixes:
- Corrected syntax bug in Debug Logging function.
v2.0.2:
Fixes:
- Fixed minor issue with install mode getting stuck on WANDOGTARGET variable.
v2.0.1:
Enhancements:
- Added Process Priority (Real Time, High, Normal, Low, Lowest) for WAN Failover. Configuration Option: Process Priority
- General Optimization.
- CHECKNVRAM is Enabled by Default for the RT-AC86U and GT-AC2900 models on new installations.
- Status Console now shows more descriptions for each WAN interface status.
- Status Console will now passively check for updates every 4 hours while running.
- Status Console will now show WAN Failover status as "Initializing" for start up of the script.
- Added new option to block IPv6 in Failover Mode from traversing Secondary WAN. Configuration Option: Failover Block IPv6
Fixes:
- Corrected issues preventing Failback in v2.0.0.
- Corrected issues with acquiring WAN Interface MAC Addresses.
- Corrected issues with Email Notifications not properly disabling.
- Restart WAN functions will now start interface if already stopped instead of executing restart command.
New Status Console Example:
Note: To change the refresh interval, go to the Configuration Menu and modify the Status Check Setting
***v2.1.3 has been released***
Release Notes:
Enhancements:
Fixes:
Thanks for your work.
Could you kindly consider implementing an option to disable the logging of Ping times in the syslog?
@Ubimo recommend you submit this request thru GitHub: https://github.com/Ranger802004/asusmerlin/blob/main/wan-failover.sh
Post in thread 'Domain VPN Routing v3.0.5 ***Release***' https://www.snbforums.com/threads/domain-vpn-routing-v3-0-5-release.92029/post-938707
Post in thread 'Dual WAN Failover ***v2 Release***' https://www.snbforums.com/threads/dual-wan-failover-v2-release.83674/post-892812
AX86Pro - 3004.388.8_4
WF was installed 2 times with the configuration removed.
WAN Failover Status:
Model: RT-AX86U_PRO
Host Name:
Firmware Version: 388.8
JFFS Scripts: Enabled
Dual WAN: Enabled
Mode: Failover Mode
WAN Failover Version: v2.1.3
Status: Failover Monitoring
Last Update: Tue Mar 25 21:17:48 MSK 2025
# WAN Failover for ASUS Routers using ASUS Merlin Firmware
# Author: Ranger802004 - https://github.com/Ranger802004/asusmerlin/
# Date: 03/11/2025
# Version: v2.1.3
Model: RT-AX86U_PRO
Host Name:
Dual WAN: Enabled
Mode: Failover Mode
# Date: 03/11/2025
# Version: v2.1.3
This is already being tracked here: https://github.com/Ranger802004/asusmerlin/issues/68
- Please report issues/bugs via GitHub issue
***v2.2.0-beta1 has been released to the beta update channel***
v2.2.0-beta1 - 03/26/2025
Enhancements:
Fixes:
Known Issues:
How do I install the beta if I have already installed the stable version?
Is this the correct command line?
/usr/sbin/curl -s "https://raw.githubusercontent.com/Ranger802004/asusmerlin/main/wan-failover-beta.sh" -o "/jffs/scripts/wan-failover.sh" && chmod 755 /jffs/scripts/wan-failover.sh && sh /jffs/scripts/wan-failover.sh install
I believe that's correct:
If you are already installed, you can enable dev mode and just simply update. It will switch to the beta channel.
***v2.2.0 has been released to production channel***
Release Notes:
v2.2.0 - 04/10/2025
Enhancements:
- Support for 388.9
Fixes:
Known Issues:
Thank you for 2.2.0 version.
I am using it on AX88U. All works fine: failover and failback. Also after reboot all are fine.
The single issue is that after a time the status is displaying "unresponsive" instead of "Failover Monitoring"/.
I tried by changing the priority (I tried all prios already), I tried bu changing the time of refresh status. None solved this "unresponsive" status.
After choosing restart from menu all are fine again for a random period.
I am on latest Firmware:3004.388.9_2.
PS: while editing this email, I discovered that the status became unresponsive again.
Firmware Version: 388.9
Dual WAN: Enabled
Mode: Failover Mode
WAN Failover Version: v2.2.0
Status: Unresponsive
My config file is looking like this now:
  Failover Monitoring Settings:
  (1)  Configure WAN0 Target           WAN0 Target: 9.9.9.9
  (2)  Configure WAN1 Target           WAN1 Target: 76.76.19.19
  (3)  Configure Ping Count            Ping Count: 10
  (4)  Configure Ping Timeout          Ping Timeout: 1
  (5)  Configure Ping Time Logging     Ping Time Logging: Enabled
  (6)  Configure Ping Time Min         Ping Time Minimum: 40ms
  (7)  Configure Ping Time Max         Ping Time Maximum: 800ms
  QoS Settings:
  (8)  Configure WAN0 QoS              WAN0 QoS: Disabled
  (9)  Configure WAN1 QoS              WAN1 QoS: Disabled
  Optional Settings:
  (10) Configure Packet Loss Logging   Packet Loss Logging: Enabled
  (11) Configure Boot Delay Timer      Boot Delay Timer: 300 Seconds
  (12) Configure Email Notifications   Email Notifications: Enabled
  (13) Configure WAN0 Packet Size      WAN0 Packet Size: 56 Bytes
  (14) Configure WAN1 Packet Size      WAN1 Packet Size: 56 Bytes
  (15) Configure NVRAM Checks          NVRAM Checks: Disabled
  (16) Configure Dev Mode              Dev Mode: Disabled
  (17) Configure Custom Log Path       Custom Log Path: Disabled
  (18) Configure WAN0 Web GUI          WAN0 Web GUI IP Address: Disabled
  (19) Configure WAN1 Web GUI          WAN1 Web GUI IP Address: Disabled
  Advanced Settings:  ***Recommended to leave default unless necessary to change***
  (20) Configure WAN0 Target Priority  WAN0 Target Priority: 100
  (21) Configure WAN1 Target Priority  WAN1 Target Priority: 100
  (22) Configure Recursive Ping Check  Recursive Ping Check: 1
  (23) Configure WAN Disabled Timer    WAN Disabled Timer: 10 Seconds
  (24) Configure Email Boot Delay      Email Boot Delay: 180 Seconds
  (25) Configure Email Timeout         Email Timeout: 30 Seconds
  (26) Configure Cron Job              Cron Job: Enabled
  (27) Configure Status Check          Status Check Interval: 35 Seconds
  (28) Configure Process Priority      Process Priority: Real Time
  (29) Configure Failover Block IPV6   Failover Block IPV6: Disabled
  (30) Configure Failover Timeout      Failover Timeout: 30 Seconds
  (31) Configure Conntrack Flushing    Conntrack Flushing: Disabled
  (32) Configure Failback Delay        Failback Delay Timer: 0
Thank you in advance for any advice!
KR,
amplatfus
Enable NVRAM checks (15) and try again.
Thanks for reply. After activation it seems that the status is OK. No more Unresponsive status.
But, please, is normal to have below errors in logs?
Jun 12 23:17:59 wan-failover: NVRAM Check - ***NVRAM Check Failure Detected***
Jun 12 23:45:04 wan-failover: NVRAM Check - ***NVRAM Check Failure Detected***
Jun 12 23:51:50 wan-failover: NVRAM Check - ***NVRAM Check Failure Detected***
Thank you,
amplatfus
Thank you,
amplatfus
It's normal....See here:
Post in thread 'Dual WAN Failover ***v2 Release***' https://www.snbforums.com/threads/dual-wan-failover-v2-release.83674/post-829932
Post in thread 'Dual WAN Failover ***v2 Release***' https://www.snbforums.com/threads/dual-wan-failover-v2-release.83674/post-830510
Is there a tutorial for this script? I need a HOW-TO because my status says WAN failover disabled but cant find a way to enable it. I dont believe the secondary 2.5GB is without IP until it is enabled.
Are problems being reported on GT-AX6000 using 3006.102.4?
Should both be active with an IP address?
Why is status FAILOVER DISABLED?
WAN1 should show connected if setup correctly and will show an IP.
Can you post pics of your setup under WAN-DUAL WAN tab. Under Secondary WAN make sure you choose the correct option i.e USB, Ethernet LAN etc...and make sure you uncheck the 'Allow failback' option when using the script.
