WANFailover WAN Failover v2.2.1 Release
I use the GUI to fail over. The script does not have any impact
1GB cable modem connection
And what's your Primary internet? I'm asking since my setup as primary is Xfinity ISP (modem and Asus router) and my secondary is TMHI (5G Gateway).
This may be similar to your issue but you're not using USB as secondary and this thread was using stock firmware Dual-wan so just a thought but will depend on what you're using so the more info you provide the better:
Post in thread 'Asuswrt-Merlin 3006.102.5 Beta is now available' https://www.snbforums.com/threads/asuswrt-merlin-3006-102-5-beta-is-now-available.95115/post-961624
GT-Ax6000 running 3006.102.4
Primary is 1 GB fiber connection with cable modem based (Spectrum) 1 Gb for secondary.
Add Ons: AMTM 6.0.2 Diversion 5.4.5, SkyNet 7.6.4, Scribe 3.2.1, uiScribe 1.4.5, Unbound 3.25, BackupMon 1.8.22
Sometimes options of the script, specifically manual failover, seem to run to completion there is no change in the configuration. Others run and post the "failover not enabled, See Logs message". I only saw the cron job posted once, and I have no idea what I did to make that happen, as the script hangs. At no time have I had a hot standby, even when I reverse the positions and put the fiber ONT on the secondary port which suggests. I get log postings of "wan connected" occasionally and those events don't kick off the wan-event script.
Could there be a difference in downloading from AMTM or using the command line?
It's best to download thru AMTM. However it's best if you enable debug logs and submit it thru Github for further assistance.
Enable debug logs:
Post in thread 'Dual WAN Failover ***v2 Release***' https://www.snbforums.com/threads/dual-wan-failover-v2-release.83674/post-924180
Additional info:
Post in thread 'WAN Failover v2.2.0 Release' https://www.snbforums.com/threads/wan-failover-v2-2-0-release.93799/post-947532
Well after testing using a minimal config I found the cable modem NEVER gets an IP as the standby in failover mode. It never went into and maintained hot-standby status. If I set the dual WAN to load balance and then install the WF script, everything works as expected. I believe the issue is the cable modem is expecting and not getting some status or signal. I ruled out DNS, NTP - and the cable modem techs are by-the-book-Bob official KB oriented so no help there. I'm good with the availability insurance I have in this configuration.
Hi @Ranger802004 , I’m having issues with the wan-failover script on my RT-AX86U (updated to the latest Merlin firmware). Every now and then I find the script in an “unresponsive” state, apparently without any specific reason. I’m attaching the log (I anonymized it, so please ignore the fake IPs). Along with this, I’m also running several other scripts (spdmerlin, connmon, ntpmerlin, etc.). Can you figure out where the problem is? Thanks a lot!
Open a GitHub issue
@Ranger802004 still love the script thanks so much! Finally upgraded from a USB LTE stick modem that needed regular reboots to a 5g gateway as wan2 that stays hot standby perfectly. Wondering if you know anyway to run a speed test on wan2 while it is in hot standby mode?
You can install Domain VPN Routing, create a policy mapped for that WAN in particular and then add domains for the speed test servers you want to use or add a rule that maps the IP of the speed test server to WAN1 in policy routing.
Is there any information on how to get the email notification working? On the AIprotect section I can’t find any place to enter my email. I only find a link to the Asus mobile app, but no email to add there either. There is only notifications for the app, I don’t know if that should work? But everything turned on but I get no notifications when the failover is active.
In amtm enter "em" (without the quotes). Set up your email there, then enable it in WANFailover.
@Ranger802004
Was looking in the wan-failover logs for something else and saw that it is complaining on startup about the version of Merlin I'm running. Seems to work fine, I've been on 388.10_0 and then 388.10_2 for months now I think on my RT-AX86U? :)
I'm definitely running 2.2.0, with dev mode activated.
Dec 19 12:17:24 AsusRouter wan-failover: System Check - Version: v2.2.0
Dec 19 12:17:24 AsusRouter wan-failover: System Check - Checksum: 88ddbb5b9a35a8c9e2c66bd31f4eeca01cc74808334a4de70acc43e791715619
Dec 19 12:17:24 AsusRouter wan-failover: Debug - Firmware: 388.10
Dec 19 12:17:24 AsusRouter wan-failover: System Check - ***388.10 is not supported, issues may occur from running this version***
Dec 19 12:17:24 AsusRouter wan-failover: System Check - IP Version: 5.11.0
@Ranger802004
This is normal warning message. It should be running smoothly!
Post in thread 'Ranger802004 Dual WAN Script Question' https://www.snbforums.com/threads/ranger802004-dual-wan-script-question.83191/post-820073
@Ranger802004
It’s benign, just means I haven’t added it to the built in list of support versions. I am likely to deprecate this function soon anyway. You can safely ignore it.
Is add-on still supported in the newest versions? Wondering since there hasn't been much activity on the thread recently.
I was also wondering if I should disable ASUS version of their Failover before installing the add-on?
Yes still supported.
Requirements:
- ASUS Merlin Firmware v386.10 or higher
- JFFS custom scripts and configs Enabled
- Dual WAN Enabled
- ASUS Factory Failover Disabled (Network Monitoring Options, Allow Failback Option under WAN > Dual WAN)
More info and report any issues here:
asusmerlin/wan-failover-readme.txt at main · Ranger802004/asusmerlin https://share.google/mGwZlu473PsMcl7ov
Hoping someone can help. Failover occurs but...
1. When I test (pull the Primary cable) ASUS's Dual WAN shows the connection fails over but when I reconnect the Primary cable it never fails back. It just shows the Primary as a hot-spare?
2. After failover, traffic is not routed to my LTE device.
device config...
<< ASUS GT-AX6000 >>
Primary WAN (WAN): Cable Modem
Secondary WAN (LAN-1) *to RUTX11 LAN-1 for failover
- Dual WAN enabled (Disabled: Allow Failback, DNS Query, Ping)
- Ranger scripts, default settings
<< RUTX11 - LTE modem >>
WAN port (WAN) : Static IP 192.168.2.2 * to network for management UI
LAN port (LAN-1) : Static IP 192.168.3.2 *to ASUS LAN-1 for failover
WAN Failover Status:
Model: GT-AX6000
Host Name: GT-AX6000-A7B8
Firmware Version: 102.7
JFFS Scripts: Enabled
Dual WAN: Enabled
Mode: Failover Mode
WAN Failover Version: v2.2.0
Status: Failover Monitoring
Last Update: Fri Mar 13 13:37:26 MDT 2026
WAN0:
Status: Connected
Primary: Yes
IP Address: 76.155.44.108
Gateway: 76.155.40.1
Interface: eth0
MAC Address: 00:1C:73:00:00:99
WAN0 Target: 8.8.8.8
Packet Loss: 0%
Ping Time: 17ms
Last Update: Fri Mar 13 13:37:20 MDT 2026
WAN1:
Status: Connected
Primary: No
IP Address: 192.168.3.1
Gateway: 192.168.3.2
Interface: eth4
MAC Address:
WAN1 Target: 8.8.4.4
Packet Loss: 100%
Ping Time: N/A
Last Update: Fri Mar 13 13:37:24 MDT 2026
