Webdav on Asus Ac68u
Xerxist
Hi All,
I've been playing around with webdav to synchronize my pictures from my phone to the routers attached disk.
One program which worked with the Asus AiCloud webdav interface is "Webdav file manager" but it lacks some functionality.
The other which pretty much has the right functions is "FolderSync" but I get an error when uploading files to the drive.
The error I'm getting is "expectation failed" which should be able to resolve by editing the lighttpd config file but i can't seem to find it.
It's a pretty neat feature to make scheduled backups from your pictures(or anything you want) directly to your router from anywhere so I like to give it a try.
Can anyone point me to the configuration file for the Aicloud?
Sent from my GT-I9505 using Tapatalk
Got it working :)
For someone who want to play around with this too.
To make this work login with telnet on the router.
Type in "vi /tmp/lighttpd.conf"
Press insert
Add the following line.
server.reject-expect-100-with-417 = "disable"
Press escape.
Press :
wq and press enter.
Find the process and kill it to load the new configuration.
Type: ps
Finde the process /usr/sbin/lighttpd -f /tmp/lighttpd.conf - D
Type kill (the process id that you found)
Start the service again.
/usr/sbin/lighttpd -f /tmp/lighttpd.conf -D
Now FolderSync works fine with the AiCloud
