Looking for a detailed option by option review, explanation, etc., thank you
I had an issue with a Dell laptop running Linux that Wifi after a few hours for no reason will get disconnected, after I disabled the options you suggested in Wireless Professional, all the disconnections are gone, it uses an Intel AX211 adapter, maybe is the Linux driver, because in Windows doesn't happens. Thank youFor far most users and applications the majority of default router settings will work well.
Advise one: write down the settings changes you make from Factory Defaults.
Then start like this from Factory Defaults:
Usually the following settings are recommended as well (they avoid the use of non standard features that often cause wireless issues):
- Router Login Name.
- Router Login Password.
- WAN Connection Type, and what is required to connect to the Internet.
- Wireless SSID's and WPA Pre-Shared Key's.
- Leave everything else default.
Further setting changes shall only been made when there is a need and if you understand the purpose.
- Advanced Settings - Wireless - Professional - 2.4 GHz:
- Modulation Scheme: Up to MCS 7 (802.11n)
- Airtime Fairness: Disable
- Explicit Beamforming: Disable
- Universal Beamforming: Disable
- Advanced Settings - Wireless - Professional - 5 GHz:
As a note: the blue part is how I write down my setting changes from Factory Default in a text file.
Thread starter | Title | Forum | Replies | Date |
B | Where's the Short Guard Interval setting in AsusWrt? | ASUSWRT - Official | 2 | |
Where is Firmware Image v3.0.0.4.388.22525 for RT-AX68U? | ASUSWRT - Official | 18 |
Welcome To SNBForums
