wireguard not working on asus rtax86
hash70
i recently moved from bt to virgin 1gig .never had a issue like this before setting up a surshark wg profile ,wg was working great on 388 up until last week before i changed from bt to virgin.done a nuclear reset but i’m getting a error saying i need to input a number between 1- 655,posted a screen shot below,can get it setup no problem with openvpn but want wg working,was on the latest fw but downgraded to 388-21709 thinking this would fix it
Endpoint Port remove everything after 51820
got wireguard working somewhat but it keeps losing internet connection after a few minutes,had a look in the logs and a lot of stuff i don’t understand and ever seen before,obviously moving from bt to virgin is doing something as it worked fine until i switched over last week
The problem with the Endpoint port had nothing to do with your ISP. Same thing happens to me.
It’s the way that the conf file gets imported.
Consumer ISPs don’t like VPNs. They either try to block the connection or throttle the speed.
The problems you’re having are “par for the course” as they say. You need to outsmart them.
