Wireless antenna makes no difference
deanfourie
Hi, I have a weird issue with a wireless antenna, a Yagi.
When connected to my laptop via a UFL to my antenna which I believe is a Yagi.
However, when doing so it makes no difference to the WiFi signal at all.
The antenna is a L-Com HG2415Y-NF Yagi Antenna 2.4.G
Any ideas?
ok - be an idiot - it's a multple radio device - so you need more than one antenna...
Sorry, do you mean the interface in the laptop is a multiple radio device? From the factory, it only had one antenna connected.
Maybe a Y split antenna.
Most single path cards have a diversity path...
If not, get a better card, not a better antenna...
I understand, my only question is if it's has a diversity path, how come it is only using one antenna by default and getting perfectly good range with that one antenna from stock
