alexcomputerhelp
The wpa2 security for both Amazon devices of mine is psk. In the router configuration only aes may be selected. Did I skip over a basic step in the router options? AC56U. Thanks.
No. WPA2-Personal is the same as WPA2-PSK. The encryption (AES) is something different.Did I skip over a basic step in the router options?
It fails authentication. Not connecting.No. WPA2-Personal is the same as WPA2-PSK. The encryption (AES) is something different.
Try a shorter password.More than 15 character passcode.
for me you had another problemI have found in the past some devices dont like to connect if the 2.4G and 5G password is the same. Try to set different ones to test.
Sorry I did in fact mean SSID.for me you had another problem
there would be no sense anymore for same SSID 2G/5G if I had to use different passwords, I would even not know which password to use as I only see the SSID without band information in Windows!
We use essential cookies to make this site work, and optional cookies to enhance your experience.
