1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
YazFi - enhanced AsusWRT-Merlin Guest WiFi Networks
Discussion in 'Asuswrt-Merlin' started by Jack Yaz, Apr 8, 2018.
  1. JaimeZX
    JaimeZX Regular Contributor
    Mar 10, 2018
    129
    I'll qualify that by saying the external HD I have as a Samba share on the router is accessible by any machine on the router if it has the correct password.
    daviworld likes this.
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. Jack Yaz
    Jack Yaz Very Senior Member
    Apr 20, 2017
    1,188
    Yes...that's odd, because my samba share on the router (all 4) cannot even be reached for authentication! Perhaps we need to sort out a screensharing session so that we can see what's going on there.
  4. JaimeZX
    Mar 10, 2018
    129
    Dunno. But I'm happy with it as-is! :D
    Jack Yaz likes this.
  5. Paulo Pereira
    Paulo Pereira New Around Here
    Mar 27, 2018
    3
    Hello everyone, does any way to yazfi work in AP Mode??? If not, is there a way to work arround??
    Tanhs in advance
  6. Jack Yaz
    Apr 20, 2017
    1,188
    Unfortunately it wont work in AP mode
  7. mxyz
    mxyz New Around Here
    Dec 17, 2017
    2
    ^ +1 for this ^
    I've got two AC68Us; the main one in the house in router mode, the other in the garage in AP mode, connected via ethernet. Same SSID, moving between them now seems perfectly seamless.
    What I need is a separate guest network on the AP mode Router2. The guest network could be on Router1 also, if it's easier since its already doing the routing, but would still need to be on Router2.
    Router1 is where the phone line, and modem are so they cant be easily swapped. The two simple solutions that I'm trying to avoid are, plug in a third router or put them both in router mode.
    I've found some router only features, like VPN, work just fine in AP mode, set up by manually going to the page, start and stop the service with a script.
    It doesn't look like AiMesh repeats the main router's guest networks, that would be an ideal solution. When it was first released I tried it and it was a disaster, I'd give it anther chance if it did guest networks.
    I guess what I'm looking for is advice or direction before I start experimenting, screw things up, then put it back together the way it was.
  8. HuskyHerder
    HuskyHerder Regular Contributor
    May 12, 2017
    163
    It, AiMesh does not support Guest Network's... in my reading, that is. I am giving it a try currently.
  9. Grisu
    Grisu Very Senior Member
    Aug 28, 2014
    1,066
    probably with aimesh phase 2, some of next firmwares will support guest-WiFi on nodes.
    HuskyHerder likes this.
  10. Jack Yaz
    Apr 20, 2017
    1,188
    Might be possible to do something with vlan tagging on the AP guest interfaces, but that goes beyond the current scope of YazFi
    HowIFix likes this.
  11. Jack Yaz
    Apr 20, 2017
    1,188
    I'd like to but I don't have the free time to write a menu driven script at the moment
    HowIFix likes this.
  12. Jack Yaz
    Apr 20, 2017
    1,188
    I know, I do want to make it easier to use, but the new job is taking it out of me :(
    I have got lan access working on my personal version, I need to make it robust and then i can add it to the main script :)
    HuskyHerder and HowIFix like this.
