Hello folks,
I am in the market for a new/refurbished router. I do not need the latest tech but something that works with my older devices.
For e.g. My laptops are 7-8 years old, working great, no need to replace them for another 3-4 years unless something goes wrong.
Our phones are Galaxy S4 and HTC One X. The tablets are from Apple Generation 1 era. All tech working good to our needs so there will be no update and even if there is, I do not plan to buy the latest stuff. I will be buying some refurbished 2-3 years old phone/tablet.
The only problem with my router selection is, probably, the number of networks that I get in my apartment and a possibility of conflict or similar (don't know the technical term). Following is the image of networks I get in my apartment.
I have Verizon G1100 gateway but I do not get any signal in the bedroom (and my apartment is really small, just 750 sq ft). I have moved that router to various places but the network remains sketchy.
So I guess, my questions are,
- What router options do I have in this case?
- Do I really need AC2300 and above type of routers? or older like AC1200 or even N900 would do the job?
- In an ideal case, I really do not want to use a repeater.
- Ideally, I do not want to pay more than $70-$80 for the router. As I said earlier, I am fine with the refurbished routers as long as they do the job.
Many thanks for reading thus far. I appreciate all suggestions.
