MichaelR64
I am running a AC87 with latest fw, 378.56_2.
I have configured and used 2 OpenVPN servers successfully for a while on it.
I have a PIA subscription and managed to get the OpenVPN client and PPTP client working.
Because of throughput issues i ditched the use of the OpenVPN client and now only use the PPTP client.
My problem is that when i enable both the OpenVPN servers and the PPTP client the OpenVPN servers are unreachable from the internet.
As soon as i disconnect the PPTP client on the router the servers can be found and connect.
Is this a limit in the system or can i have both up and running.
Ideally i would like to be able to specify which openvpn server goes tru the PPTP tunnel.
But if both have to go tru that would be ok to.
Currently i can not use them together with my PPTP client enabled.
I remember having read somewhere that it is not possible but can not find it.
Perhaps someone can shed some light on this ?
I want to add this also happened when i had the OpenVPN client enabled.
I just switched to PPTP because of performance reasons.
