FTC
Hi, I have been playing with QoS in order to make sure that my IPTV traffic gets max priority. I am using a RD-AC3200 and my IPTV traffic goes through vlan2. I am using hggomes, a merlin derivative based on 380.4180.
I have been able to get some success by bandwidth limiting the more wan consuming devices, however this is not an optimal solution since the limit applies even if IPTV is not being used. Now, what would be the easiest way to configure some sort of working QoS that would achieve this objective ? I've read that traditional QoS is broken and I seem to be unable to configure adaptative QoS in a succesfull way (tv does still fluctuate if others are using the wan with high bandwith). is QoS supposed to work for all defined vlans ?
If this can not be achieved w/GUI, even a command line solution would be appreciated.
Thanks in advance
Thanks in advance
