enable internal microSD slot
darksamus
Merlin,
I have a 2gb microsd card inside the router. Where do I enable it so that it'll show up as /mnt/sda1/
Is enabled automatically but you can't see it in router ui, open a terminal and type:
mount
You need to
- Partition it with fdisk and
- Format it with mkfs.ext2 or mkfs.ext3 and
It will work! :)
As your Asus router as (a kind of) Linux, you can find plenty of how to's make this work!
With kind regards
Joe :cool:
You need to
It will work! :)
With kind regards
Joe :cool:
The microSD is already format into ext2 since it is being use by the router with TomatoUSB. I just wanted to try out Merlin's firmware with the microUSB on it but wanted to "do my homework" before I load Merlin's firmware.
With Merlin's firmware, can I point my OpenVPN certs, keys, etc to the microSD? instead of pasting the keys into the router? Reason is I want to save the NVRAM space as much as possible.
