jester7677
Looking for upgrade advice. I've done a bit of reading but I don't want to sway the jury. Would like to stay under $399
I currently have a Netgear WDNR3700 600N router in a 3000+ sq foot house, positioned at one end of it, in the corner room, of the rectangular house. Upside is it's on the middle floor, but I can't move it and I can't run wires at this point as that would require a large amount of money. All walls, and ceilings of all floors are dry walled. I moved the channels around, and I have moved the router around within the room where it is, as well as the Horizontal/Vertical positioning of the router....
The router is mainly used for Wifi. Right now we are experiencing a decent amount of signal quality/strength fluctuation and having to reboot the router twice a week. The far end of the house gets bad wifi. There are four of us in the house and it gets worse when we have guests. It is used by...
3 laptops (Newer and I believe they all have AC)
4 iphones (Newer)
3 ipads
2 xbox ones
1 TV
1 Direct TV system
Wifi Printer
4 iphones (Newer)
3 ipads
2 xbox ones
1 TV
1 Direct TV system
Wifi Printer
