Running 3.0.0.4.374.34_2 on a RT-AC66U
I now have attached 2 HDD's to my router by using a self powered USB hub.. WORKS
the disks are initialized properly..
SAMBA works..
Now the question is.. how can I see how much is used and free on each..
I know I can telnet and use df -h or partet, if it's supported in wrt..
but would it be possible to give this information nicely structurized in the GUI?
of course if you attach only 1 HDD to each USB port the available space is in the
"network map" visible.. but attaching 4 HDD's for example by using a USB Hub..
this seems to be impossible in the current Asus GUI..
Since it's there already in the GUI, it shouldn't be too much work to enable this for
all HDD's attached to a single USB HUB..
Thanks for all your hard work Merlin!
Your wrt is the only one capable of handling multiple HDD and 2+ Terabyte properly..
Tried Brainslayer, Kong, Tomato.. they all fail at some point..
Merlin-wrt is the only wrt I can get everything to work on 1 single properly configured router.
SAMBA works..
